white-green wire mystery, where do these 2 wires go? |
jackspratt |
Mar 6 2022, 10:23 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Here is a pic of 2 wires. One green and one white. They are coming off a harness near where the 2 fuel lines fan side are. Next to distributor. Can someone please explain where they plug in to? If they do at all. Also, can't get injectors to fire. and what does that plug with the boot on it that is plugged into the fuel line middle junction do?
Thanks Teeners! |
jrmdir |
Mar 7 2022, 03:33 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Hello Jack:
We were all Newbies at one point and many, like me, went through the same initial confusion you're finding - trying to sort out a non-running engine that we knew nothing about. But it would be good if you could consolidate your questions. For example, some of us just today already explained in good detail in another thread: what does that plug with the boot on it that is plugged into the fuel line middle junction do? Not trying to discourage asking questions - rather to help you get this car running as everyone here will want to do. Because we've all been there. I, too, was hoping there was one obvious thing that would suddenly allow the engine to fire up. So I ignored a lot of good advice telling me to go through a methodical check out of all systems in logical order. But in the end I wasted a lot of time since, like I'm certain you will find, there are too many variables and no substitute for following a time-tested process. I recommend getting prepared by obtaining: A wiring diagram Ohm Meter Fuel pressure gauge FP relay jumper - this will let you run the pump at any time (see photos) This will help us better guide you on this journey. Cheers, Ron |
jackspratt |
Mar 7 2022, 08:26 PM
Hello Jack: We were all Newbies at one point and many, like me, went through the same initial confusion you're finding - trying to sort out a non-running engine that we knew nothing about. But it would be good if you could consolidate your questions. For example, some of us just today already explained in good detail in another thread: what does that plug with the boot on it that is plugged into the fuel line middle junction do? Not trying to discourage asking questions - rather to help you get this car running as everyone here will want to do. Because we've all been there. I, too, was hoping there was one obvious thing that would suddenly allow the engine to fire up. So I ignored a lot of good advice telling me to go through a methodical check out of all systems in logical order. But in the end I wasted a lot of time since, like I'm certain you will find, there are too many variables and no substitute for following a time-tested process. I recommend getting prepared by obtaining: A wiring diagram Ohm Meter Fuel pressure gauge FP relay jumper - this will let you run the pump at any time (see photos) This will help us better guide you on this journey. Cheers, Ron I'm going to take this advice. Going to get a FPressure tester. I see now where that goes. Thanks to your pic. Question: Are you plugging that brown wire in and then pulling it out just to turn on the fuel pump on and off? As you are testing or does it just left in? |
Lo-Fi Version | Time is now: 27th September 2024 - 09:36 AM |
