white-green wire mystery, where do these 2 wires go? |
jackspratt |
Mar 6 2022, 10:23 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Here is a pic of 2 wires. One green and one white. They are coming off a harness near where the 2 fuel lines fan side are. Next to distributor. Can someone please explain where they plug in to? If they do at all. Also, can't get injectors to fire. and what does that plug with the boot on it that is plugged into the fuel line middle junction do?
Thanks Teeners! |
jrmdir |
Mar 8 2022, 07:35 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Great!
Only for testing. Otherwise you need to have the engine running to see what's happening with the pressure. And you need to pull it out when done or else the pump will keep running. And it just looks brown in the photo. It's bare copper wire - but you can use any sort of wire that will fit snugly into the relay socket holes. Ron |
Lo-Fi Version | Time is now: 27th September 2024 - 09:05 AM |
