Fuel tank bay holes, Holes ion floor/pan |
RandyE |
Mar 8 2022, 11:44 AM
Newbie Group: Members Posts: 13 Joined: 5-March 22 From: california Member No.: 26,373 Region Association: None |
914Sixer |
Mar 8 2022, 11:57 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Small hole was for brake fluid over flow line on 70-71 cars, not used on later years. Others are drain/vent holes.
ndfrigi |
Mar 8 2022, 12:42 PM
Advanced Member Group: Members Posts: 2,953 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Small hole was for brake fluid over flow line on 70-71 cars, not used on later years. Others are drain/vent holes. Yes sir Mark two small holes for brake fluid line is at the driver side and those holes on the picture I think one for water drain from the fresh air box and the other hole for the fuel filler neck drain. Big hole is an access hole from the bottom. |
RandyE |
Mar 8 2022, 06:24 PM
Small hole was for brake fluid over flow line on 70-71 cars, not used on later years. Others are drain/vent holes. Yes sir Mark two small holes for brake fluid line is at the driver side and those holes on the picture I think one for water drain from the fresh air box and the other hole for the fuel filler neck drain. Big hole is an access hole from the bottom. Thank you for your feedback! I appreciate it! |
Lo-Fi Version | Time is now: 27th September 2024 - 06:44 AM |
