Simple Anti-Theft Switch, Wiring suggestions |
FlatSix |
Mar 14 2022, 09:42 AM
English Member Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 |
So I want to install a switch hidden under the dash to stop the engine starting.
Having done a search, the black/purple wire going to the tachometer seemed a likely candidate to break the circuit. However, when I disconnected it from the tach, the car would still start! Which wire should I use? The engine is a 1973 2.0 four cylinder with fuel injection. |
vitamin914 |
Mar 14 2022, 12:19 PM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
I have a switch for the fuel pump and auxiliary oil cooler fan. Both are in plain sight and unlabelled on the dash (plus, I have a battery disconnect for storage and electrical work). More than once I have forgotten to turn on the fuel pump only to have the engine die shortly (carbs). Fooled myself several times thinking something failed because I forgot about the switch - D'oh!
Maybe reconnect the the seatbelt interlock under the passenger seat that most have defeated (by connecting the yellow wires together). Then mount the switch under the passenger seat. Nothing under the dash to worry about in that case. Not sure if the '73 had the interlock... |
Lo-Fi Version | Time is now: 27th September 2024 - 06:19 AM |
