How test/inspect 2.0L DJet throttle body before swapping it in? |
Tdskip |
Mar 16 2022, 07:05 PM
Advanced Member Group: Members Posts: 3,697 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi - the '75 DJet car has a stumble that happens at a couple points in the rev range and at certain RPMs when the throttle is held constant. It rarely happens when the throttle is being exercised up/down the RPM range (like accelerating through turns etc).
I'm thinking worn throttle body "fingers" or the trace pad they travel against (yeah, wrong terms I know) but I believe this could also (maybe) be a sticky advance weight in the distributor. Any why to test the spare throttle body so I don't swap out the wrong thing? OR Should I just pull and open the plastic cover on the one I have to see what is up? Doesn't look that hard to remove it. What say you gentlemen, and please do liberally apply terminology dope slaps. Thanks! |
Lockwodo |
Mar 17 2022, 08:08 AM
Member Group: Members Posts: 204 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
Hi - the '75 DJet car has a stumble that happens at a couple points in the rev range and at certain RPMs when the throttle is held constant. It rarely happens when the throttle is being exercised up/down the RPM range (like accelerating through turns etc). I'm thinking worn throttle body "fingers" or the trace pad they travel against (yeah, wrong terms I know) but I believe this could also (maybe) be a sticky advance weight in the distributor. Any why to test the spare throttle body so I don't swap out the wrong thing? OR Should I just pull and open the plastic cover on the one I have to see what is up? Doesn't look that hard to remove it. What say you gentlemen, and please do liberally apply terminology dope slaps. Thanks! You're referring to the throttle position sensor. You can try disconnecting the electrical connection to the TPS and see if the hesitation problem remains. Rebuilding the TPS is straightforward and the board is ~ $50. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:35 AM |
