Oil leak, Flywheel area |
930cabman |
Mar 25 2022, 12:16 PM
Advanced Member Group: Members Posts: 3,544 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
New build and have her running on a test bed/rolling cart for engine/trans installation. All seems tight with the exception of the rear main area. Short of dis assembly or slathering the cam plug and oil gallery plugs with sealant, has anyone tried pressurizing the oil system and visually looking for a leak? Everything looks ok, but she drips every 4 or 5 seconds when running.
Thanks in advance |
iankarr |
Mar 26 2022, 09:09 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,512 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Forgive the simple question, but is the o-ring installed in the rim of the flywheel? It’s often overlooked… and no bueno for leaks…
930cabman |
Mar 26 2022, 09:21 AM
Forgive the simple question, but is the o-ring installed in the rim of the flywheel? It’s often overlooked… and no bueno for leaks… Yes, new O ring, thanks for the reminder New seal is made by Elring I have a couple old flywheels laying around, I am thinking to machine the center hub off, bolt it up to the crank and pressurize the system with 70 psi of shop air through the pressure sender. Hopefully seeing will be believing Thanks to all for the replies, I am seeing this is not uncommon |
Lo-Fi Version | Time is now: 27th September 2024 - 07:59 AM |
