"Trailer-hitching" bucking problem, Rapid detrioration from running perfectly |
boxster914 |
Apr 12 2022, 11:18 AM
Member Group: Members Posts: 74 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
Hi everyone
My perfectly running 71 914 1.7 D-jet has deteriorated rapidly this past week. Early in the week I noticed what felt like a power drop out during a drive. It was very slight and only happened once and I wasn't sure I didn't cause it by unconciously lifting off the gas. The next drive it happened a few times and was more pronounced. It was then that I knew this wasn't an imagined problem. On the third drive it was like a bucking bronco, surging and stopping and the engine cut out a few times. It was undriveable. Today it will start but won't run. The engine cuts out when I try to rev it and the red light comes on. I've done some searching here but haven't been able to draw any conclusions or come up with an actionable strategy to diagnose the problem. I'm seeing people trace it to spark plug wires, air fuel ratios and bad distributors. Is there a step-by-step process that you can recommend for me to get to the cause of this? (I'm a newb so I probably will need help with abbreviations like AFR, TPS, etc.) Here is a video of it's rough idle yesterday when it was still running. https://youtu.be/n61CP6O8UgM |
ClayPerrine |
Apr 12 2022, 01:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
"and the red light comes on."
Which red light? If it is the generator light, it may be a bad alternator causing the voltage to drop too low for the FI to function correctly. Clay |
Lockwodo |
Apr 12 2022, 01:30 PM
Member Group: Members Posts: 204 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
"and the red light comes on." Which red light? If it is the generator light, it may be a bad alternator causing the voltage to drop too low for the FI to function correctly. Clay Hmm, I hadn't thought about voltage drop off affecting the FI system. The battery on my car is on a trickle charger and seems fully charged when cranking the starter. No red alternator light in my case. Question: does the FI system run off the battery, in other words, if the battery is fully charged but the alternator is sub par, could the FI system be affected? |
Lo-Fi Version | Time is now: 27th September 2024 - 02:15 PM |
