"Trailer-hitching" bucking problem, Rapid detrioration from running perfectly |
boxster914 |
Apr 12 2022, 11:18 AM
Member Group: Members Posts: 74 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
Hi everyone
My perfectly running 71 914 1.7 D-jet has deteriorated rapidly this past week. Early in the week I noticed what felt like a power drop out during a drive. It was very slight and only happened once and I wasn't sure I didn't cause it by unconciously lifting off the gas. The next drive it happened a few times and was more pronounced. It was then that I knew this wasn't an imagined problem. On the third drive it was like a bucking bronco, surging and stopping and the engine cut out a few times. It was undriveable. Today it will start but won't run. The engine cuts out when I try to rev it and the red light comes on. I've done some searching here but haven't been able to draw any conclusions or come up with an actionable strategy to diagnose the problem. I'm seeing people trace it to spark plug wires, air fuel ratios and bad distributors. Is there a step-by-step process that you can recommend for me to get to the cause of this? (I'm a newb so I probably will need help with abbreviations like AFR, TPS, etc.) Here is a video of it's rough idle yesterday when it was still running. https://youtu.be/n61CP6O8UgM |
mepstein |
Apr 12 2022, 01:49 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Also check all the grounds. Easy to do and while you are doing it, you may notice something else.
Lockwodo |
Apr 12 2022, 01:53 PM
Member Group: Members Posts: 204 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
Also check all the grounds. Easy to do and while you are doing it, you may notice something else. Thanks Mepstein, you're right and that's related to the potential voltage issue. My understanding is the most important ground points for the FI system are the negative battery cable to chassis connection, the connectors that are on the top rear of the engine under the air cleaner, and the transmission to chassis ground. I've taken care of the first two and the tranny to chassis ground point is on the list. |
Lo-Fi Version | Time is now: 27th September 2024 - 02:32 PM |
