Windshield wiper woes |
914werke |
Apr 19 2022, 05:27 PM
"I got blisters on me fingers" Group: Members Posts: 10,561 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So, Ill preface this with a short story.
Customer brought a car to me for Fuel line update. A process that includes the removal of the tank ... All went well & the car went back together & outside to get a bath prior to PU. After its wash hop in to move it, hit the wipers that creak to life, sweep .5 way across the windshield ...& stop. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/hissyfit.gif) So this is a cautionary tale to suggest if you've never serviced you Windshield wiper assembly, you might consider it. Those of you in the warmer climes probably are less concerned but here in the PNW their function is pretty important, if you drive your car. The design of the cowl lends itself to allowing water to get into the shafts & of course rust to follow. Even rusted they may work ... albeit slowly. The motor laboring to grind the shafts in the bushed collars until... either the motor gives it up or they just seize. Like this customer's car. (IMG:style_emoticons/default/headbang.gif) Motor is fine, the shafts rusted to the point they no longer will turn. |
NARP74 |
Apr 27 2022, 04:24 PM
Senior Member Group: Members Posts: 1,175 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Good advice there, keep your shafts lubed as they get older. Need to be in working order in case the need should arise.
Root_Werks |
Apr 27 2022, 09:34 PM
Village Idiot Group: Members Posts: 8,425 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Good advice there, keep your shafts lubed as they get older. Need to be in working order in case the need should arise. (IMG:style_emoticons/default/agree.gif) I like this thread, never had to take a 914 unit apart. Not a light task! |
Lo-Fi Version | Time is now: 27th September 2024 - 02:09 PM |
