Sheared off bolt head, Front axle |
vitamin914 |
May 2 2022, 11:13 AM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
While reading the thread about 4" hole under the gas tank and the protective cover for the steering rack I decided to get under mine to see if I need the protective cover. Yes, I do, and I found something I did not expect a sheared-off bolt head. (IMG:style_emoticons/default/unsure.gif)
See photos. Right side ok, left side not so good. No clue what caused it was but it is painted over and not fresh - (IMG:style_emoticons/default/mad.gif) must have existed when I bought the car. I know this is not correct and needs to be fixed. I don't know what these supports are holding but I suspect it is the front axle. Is it dangerous? How urgent should it be? Anyone have a feel for the difficulty in removing that sheared bolt? |
flyer86d |
May 2 2022, 02:26 PM
Member Group: Members Posts: 443 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
I would do what Mark said. Weld a nut to the stud and back it out. If it breaks off, do it again until it comes out. I have used this method many times. It works great on broken exhaust studs also
Charlie |
mepstein |
May 2 2022, 02:48 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would do what Mark said. Weld a nut to the stud and back it out. If it breaks off, do it again until it comes out. I have used this method many times. It works great on broken exhaust studs also Charlie It’s what shops do all the time since they can’t wait days for penetrating oil. I’ve also found that impact guns work well for this. They know the corrosion free from the repeated hammering. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:51 AM |
