Fuel tank relocation to rear? |
Mendivil26 |
May 10 2022, 02:25 PM
Newbie Group: Members Posts: 31 Joined: 26-July 18 From: Riverside, Ca. Member No.: 22,344 Region Association: Southern California |
Story time:
Last time I parked my '75 2.0 to restore the front suspension, it was running relatively fine. As usual, a simple task estimated to take a few weeks turned into months, due to lack of time & budget. A few months go by and I notice the interior is flooded in gas, thankfully the car had no carpets and nothing caught fire. I did my research and diagnosed the leak came from the plastic fuel lines that go through the tunnel; simple enough, I'll replace them with SS lines. I go ahead and clear the interior of any remaining fuel; drain the rest of the gas tank, only to notice the horrible condition it's in; chunks of rust coming out of it. Now I not only have to replace the fuel lines but I also have to either restore the tank or replace it (dansk tank $230 plus SS line $170). My goal with this car is to turn it into a baja inspired 914; and since I don't really care about "originality", I wondered: what if I replaced it with a universal fuel tank used by dune buggies/prerunners (Jaz, RCI, etc) and placed it in the rear trunk? They seem to be easy to find secondhand and not so expensive. I started looking into it and noticed obviously 914 racecars have "fuel cells" but they all kept them in the front. This is a list of pros & cons I came up with, and since it hasn't been done before I assume that it'll be a very unpopular inion, so please go ahead and talk me out of it since I'm biased and can only think of reasons to actually do it. Pros: No fuel lines running through tunnel = simpler system & shorter lines. Less or just as expensive for a unique or "custom" look, since I've never seen it done before. Shifts weight to the rear, which is better for my application Cons: Safety? Rear suspension is being reinforced so the tank could be protected by the cage I'll build around it in case of a rear end accident, but the fact that it's closer to the engine and hot temperatures might be a bigger issue. Anything else I might not be considering? Has someone seen it done before? If so, please share pictures/info. Picture of how it sits right now with UTV tires, for reference: Picture of what I'm thinking of maybe doing: |
ClayPerrine |
May 10 2022, 03:08 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That is an absolutely terrible idea. The rear trunk is a crumple zone, and you would be putting the gas tank in harms way. Believe me, I know.
And putting the gas tank above the hot engine/transmission is a really bad idea too. Leave it where it was put originally. If the tank is bad, there are new ones available, or people on here have good used ones to sell. |
ValcoOscar |
May 10 2022, 03:11 PM
Garage Life Group: Members Posts: 2,468 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
That is an absolutely terrible idea. The rear trunk is a crumple zone, and you would be putting the gas tank in harms way. Believe me, I know. And putting the gas tank above the hot engine/transmission is a really bad idea too. Leave it where it was put originally. If the tank is bad, there are new ones available, or people on here have good used ones to sell. (IMG:style_emoticons/default/agree.gif) w/ Clay He's an expert in this area (ask him how he knows) Don't relocate the fuel tank. Oscar |
Lo-Fi Version | Time is now: 27th September 2024 - 12:26 PM |
