Collapsed lifter? |
Collapsed lifter? |
JMT |
Jun 8 2022, 08:27 PM
Newbie Group: Members Posts: 36 Joined: 19-August 16 From: Ca Member No.: 20,316 Region Association: None |
Hello everyone. Went for a drive today and car ran great, stopped for fuel and when I started back up I heard a horrible rattle coming from cylinders 3 and 4 valve cover. After a tow home I found this. At least 1/4" gap from rocker to valve tip. I turned the engine over slowly and did get the rocker arm to slightly open valve. I thought how could a solid lifter collapse?
I also pulled the rockers and pushrod. The pushrod was not bent. I looked down the pushrod tube and saw 'C' clips on the lifters. Is there such a thing as solid lifters with 'C' clips? Thank's for the help. |
sportlicherFahrer |
Jun 9 2022, 09:09 AM
Nothing to see here. Group: Members Posts: 1,098 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
I'd double check with Web on that lifter. Their performance lifters look like hydraulic lifters, but somehow work as standard lifters. I just finished installing a set on my engine paired with their 86a cam. Threw me for a loop when I took the lifters out of the box.
I'd also compare the stem heights on the valves and do a leakdown check. Higher likelyhood that you have a dropped seat rather than a lifter issue. BTDT. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:37 AM |
