Tranz gear oil change, Broken tooth. |
malcolm2 |
Jun 5 2022, 09:12 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Changing the gear oil yesterday. And this little gem was on the magnet. In the past year, there were 2 GRIND instances that I remember. Shifting 1st to 2nd. I remember one going around a curve and I was a leaning into the curve a bit and pulled the stick into the gate.
I have not had any struggles because of this tooth breakage. All driving and shifting seems the same as it has been since 2013. Anything I should be concerned about, or should consider? Lots of normal fine wear dust too. The tooth is in the top left corner |
r_towle |
Jun 20 2022, 01:26 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Shop around for a used trans.
Rebuild that while you enjoy the car. Trans swap is a weekend. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:29 AM |
