Valve stem seals, Anybody go bowtie on these before? |
jwalters |
Jan 17 2005, 01:13 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Had one of my heads apart--one intake valve out--and while rummaging thru all my pack-rat crap I came across one chevy intake PC seal. Soooo.......
I look at it and slide it on the valve stem--perfect fit!- (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) -just like the chevys I used to put these on--Sooooo...... I put it on the guide top--again, a perfect fit! (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Soooooo.... I put the valve back into the guide and trial fit this seal again......Perfect fit! (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Sooooo............ I leave it there and put the spring and retainer together and then compress the valve wayyyy past where stock would be--no fouling! Soooooo........ In my turbo motor I am building--these would be prudent,,,,No????? Any first hand experience running these before???? |
jwalters |
Jan 17 2005, 07:17 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) well the guides are bronze?? ( looks more like brass, but straight brass would be wayyy too soft for any application of this sort)--just like what all the V-8 guys use--self lubricating-they never really have issues unless real out of the world valve lifts and side loads are used... throw swivel feet into the picture and even more side load is taken away... If not--they are the exact same diameter as the bronze ones in a chevy V8--could easily use those. ( Wonder if Porsche / VW ripped these off the shelf for ease? ) I know there are heat issues--but only really with the exhaust ones--those can be reamed for a little more tolerance stem to guide wise--this would prevent siezing-- I am just theorizing aloud---- I am sure someone here has actually done testing on this--it makes just too much sense..it would be too beneficial to keep the internal pressure rise at a minimum. Especially seeing as how most engines last only 80k-100k ( Hopped up that is) So if they would last up to this point..hmmmmmmm I also am up and up at the V8 guys using a vacuum pump to put about 14 inches of vacuum in the block--they have reported a HP rise of up to 35 more!!!! |
Lo-Fi Version | Time is now: 26th September 2024 - 09:51 PM |
