Fuel pump options, Staying in its original location |
emerygt350 |
Apr 13 2023, 07:59 PM
Advanced Member Group: Members Posts: 2,409 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I am having a very specific issue here. Pump no longer holds pressure after shutdown. Original location, original three port pump. It still pumps great when running, but no longer holds pressure. Need to fix that and quick. Do I have to replace it or can it be repaired?
r_towle |
Apr 13 2023, 08:21 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would suggest you test the injectors, including the cold start injector.
I would also suggest you test your Fuel Pressure Regulator. If all of those are good, then you might need to replace the pump. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:35 AM |
