Advice needed on cowl-fender repair areas and rust in welds |
doug_b_928 |
May 18 2023, 10:48 AM
Senior Member Group: Members Posts: 703 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
After no progress in 2022 due to other time commitments I'm ready to get back to my restoration. Most of the rust repair on the middle and rear of the tub is done, but I still have the front end to do. I'm at a crossroads with respect to the cowl-quarter channels.
It's very difficult to see and even more difficult to get good pics but the right side channel has some spots where it has rusted through. Here are some pics: But the underside looks great to me. Here's pic of the underside which I cleaned up, rust treated, and epoxy primed several years ago. The left side fender-cowl channel is in better shape when looking down into it. Here is a pic: I removed most of the seam sealer from the underside but still need to clean it up. As shown in the pic below, there is a spot of rust but it does not look like it has rusted through, so I expect this side to clean up as nicely as the right side. So, question #1 is how to deal with these areas. There aren't many threads that deal with their repair but having studied the ones I could find I think I have a good sense of how the two pieces are welded together. It looks like it might be difficult to remove the spot welds in the door area. I believe I can do it but I'm wondering if wire wheeling, treating with metal prep, epoxy priming and then seam sealing might be what's best in this area. Obviously best is always to cut it out and get rid of any sign weakened metal but then getting the panel to look as good after the repair might be a challenge and since this location is kind of buried maybe it's better to leave the nice lines on top and treat it. On the other hand, if it's going to be an issue in the future then I'd rather cut it out and repair now. So this is the conundrum. What say the brain trust? The top side of the cowl is in nice shape and the channel for the windshield has some pitting but not perforation. I still need to take a wire wheel to the windshield channel. Here are some pics: Unrelatedly, one benefit of taking forever to do the rust repair is one gets a chance to see where rust wants to rear its ugly head again. There are 4 spots where I can see some rust on the epoxy primer. Two of them are on the left suspension console where I did the 'weld little rust areas with the mig' techniqe. Here are pics of those: And the other two are seams where new metal was welded to old. One is on the rear trunk floor crossmember and the other is below the right rear tail light. So, Is this a matter of some rust mixed in with the weld or is that there was still rust behind the area that needs to be dealt with? Attached image(s) |
doug_b_928 |
May 20 2023, 10:19 AM
Well, I'm about as far down the rabbit hole as Monreal914 et al (e.g., Brent Brock). But Montreal914's experience and decision to leave the driver's side alone says a lot. I agree, every seam on these cars with healthy metal when separated has some rust in between so a truly rust free car would need to have every seam separated and treated. But the rust in those areas is really a surface rust that I doubt will ever cause problems (if it hasn't already in the past 50 years). This channel where the rubber goes appears to be a different story as some people have bubbling in the area. I don't want to paint the car and have to re-paint it because rust rears its ugly head there, but there appears to have never been rust on the visible parts of the panels anyway so that's where the blast, wire wheel, treat, and epoxy the crevace approach comes in and might be the best course of action here.
Like Montreal 914, I too look forward to hearing what others who've done this repair have to say. Given that there are only a few threads where people have documented this repair it seems that this area may rarely get surgery, which may also be telling... |
Lo-Fi Version | Time is now: 27th September 2024 - 01:19 AM |
