Relay board |
Relay board |
Dave97 |
May 19 2024, 03:12 PM
Newbie Group: Members Posts: 44 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
Do relay boards have intermittent problems? I’m having problems with the fuel pump. I lose power to the pump. Switch relays on the side of the road no go. Get home check power at the fuse ok, take a headlight relay, powers right up. Could I have a bad board connection? Intermittent? Thanks. Dave
Dave97 |
May 21 2024, 09:30 PM
Thanks everyone. The challenge has been it is intermittent. It has stranded me twice. I can be driving along, then no fuel pump..I’m running webers I also run a ground wire from the spade connector on the board. The intermittent part makes it difficult because I have tested the wiring , pulled the gas tank then, checked power at the fuses, changed the relays around and then it works. I drive about 1;000 miles, then no power to the pump. That’s why I asked if there could be a loose connection at the relay pins or at the fuses.
What do I use to get the “tar” off the bottom to check? What do,I use to replace it when I’m done? Thanks again everyone. Dave |
bdstone914 |
May 22 2024, 07:56 AM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Thanks everyone. The challenge has been it is intermittent. It has stranded me twice. I can be driving along, then no fuel pump..I’m running webers I also run a ground wire from the spade connector on the board. The intermittent part makes it difficult because I have tested the wiring , pulled the gas tank then, checked power at the fuses, changed the relays around and then it works. I drive about 1;000 miles, then no power to the pump. That’s why I asked if there could be a loose connection at the relay pins or at the fuses. What do I use to get the “tar” off the bottom to check? What do,I use to replace it when I’m done? Thanks again everyone. Dave Test it first. Mist are good. I did have one recently that had no continuity on pin one. Connection to the trace was good. Put the whole board in boiling water for about five minutes. I use Flexseal to reseal them. Or silicone tubber. First seal the alternator cinnections with silicine ir the Flexseal will flow into the socket. Use a rubber eraser to pkug the square hole. Out the whole relay board in boiling water to soften the tar. Scr |
Lo-Fi Version | Time is now: 26th September 2024 - 09:08 PM |
