Relay board |
Relay board |
Dave97 |
May 19 2024, 03:12 PM
Newbie Group: Members Posts: 44 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
Do relay boards have intermittent problems? I’m having problems with the fuel pump. I lose power to the pump. Switch relays on the side of the road no go. Get home check power at the fuse ok, take a headlight relay, powers right up. Could I have a bad board connection? Intermittent? Thanks. Dave
Ishley |
May 22 2024, 11:02 AM
Member Group: Members Posts: 142 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
What year is it? On the earlier cars the original fuel pump was in the rear. The positive wire ran along the fie wall and terminated near the ECU/Battery. When I had issues... I made up a length of jumper wire to plug into that wire and I plugged the other end into a multi prong connector on the coil. When you turn the key the pump ran... but it got me home a few times until I figured out the issue.
Lo-Fi Version | Time is now: 26th September 2024 - 09:07 PM |
