Relay board |
Relay board |
Dave97 |
May 19 2024, 03:12 PM
Newbie Group: Members Posts: 44 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
Do relay boards have intermittent problems? I’m having problems with the fuel pump. I lose power to the pump. Switch relays on the side of the road no go. Get home check power at the fuse ok, take a headlight relay, powers right up. Could I have a bad board connection? Intermittent? Thanks. Dave
mepstein |
May 22 2024, 11:14 AM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I had an early car with a fuel pump problem that was really a relay board problem. Switched it out and the car started right up. They are 50 years old.
930cabman |
May 22 2024, 11:29 AM
Advanced Member Group: Members Posts: 3,544 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I had an early car with a fuel pump problem that was really a relay board problem. Switched it out and the car started right up. They are 50 years old. Many of us at 50 y/o can barely start at all (IMG:style_emoticons/default/beer.gif) |
bkrantz |
May 22 2024, 08:54 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I had an early car with a fuel pump problem that was really a relay board problem. Switched it out and the car started right up. They are 50 years old. Many of us at 50 y/o can barely start at all (IMG:style_emoticons/default/beer.gif) Well, scrape the crud off your bottom and re-solder your connections. |
Lo-Fi Version | Time is now: 26th September 2024 - 09:08 PM |
