NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,339 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
So my 2.0 has had a hard life, several owners, many changes. Repaired or replaced body panels, repainting, making it as unoriginal as possible. Right now, everything is black, murdered out before that was cool.
Controversy begins here... I don't like original side mirrors. Don't like the chrome, the shape, anything about them. The car came with baby tornado mirrors which elicit disdain among most of the community which I don't understand. I am not a huge fan of them, but they are installed, and badly at that. So I was thinking of a change but not sure what alternatives exist that are not the two already mentioned. Is it either or? One issue I have with the current setup is that they just used sheet metal screws through the door skin to attach the tornado mirrors. They get loose all the time and bounce around, that is a negative. I looked inside and it appears the original threaded metal mounts are intact but they might have had the top of the hole worked or covered. So if I went back to stock I would have to fill the sheet metal screws that would probably be visible and then drill the original holes out. I am trying to balance practicality with desire at this point. This car is not worth lots of metal work and door painting at this point. Should I leave it as is and move on to other items? Tons on the work list. I am on the doors now so it is in scope. |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,269 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
Drop part off at cerakote guys shop, wait a week, pick up coated part (IMG:style_emoticons/default/biggrin.gif)
Essentially it is really similar to powdercoating but the thickness is FAR thinner and works well for close interference parts like the door handles shown below. There are different types of coatings offering different properties like heat resistance. Some are not very good in terms of UV resistance and it may not be good for very high exposure areas to impacts like front bumper given the coating thickness. Normal prep like blasting of any current coating to bare is needed. Love the look Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 26th February 2025 - 07:19 PM |
