Driver174 |
Member ![]() ![]() Group: Members Posts: 114 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None ![]() ![]() |
I’m looking at a FTE master cylinder for my 1974 -4, and website says it’s for a 70-70 six, and is not compatible with my car.
I’m curious as hat the difference is between the -6 and -4. I rebuilt my complete brake system including an ATe master cylinder two years ago, and now needing to replace the it already. Was told the FTE unit had silicon seals and would withstand the heat better than seals in the ATe. Your thoughts are appreciated |
flxzcat |
Newbie ![]() Group: Members Posts: 15 Joined: 13-June 11 From: lake forest socal Member No.: 13,188 Region Association: None ![]() |
I use the 23 but I like a stiff pedal, oh, and I use Brembo Alfa front and Mercedes rear calipers.
I have a new uninstalled Ate 19mm that I purchased late last year before I found the 23mm----$200 +shipping? |
zoomCat |
Member ![]() ![]() Group: Members Posts: 189 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None ![]() ![]() |
I use the 23 but I like a stiff pedal, oh, and I use Brembo Alfa front and Mercedes rear calipers. The force at the pedal required for a given clamping force is a function of the ratio of the caliper and master cylinder pistons. If you balance things out then brake pedal effort will change little. The factory brakes /6 have both larger calipers and master cylinder, but the ratio is little very close to the same. Interestingly the hydraulic line pressure does change, largely based on caliper piston area, which is why the six has a different pressure regulator and why racing applications often replace the it. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,776 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I use the 23 but I like a stiff pedal, oh, and I use Brembo Alfa front and Mercedes rear calipers. The force at the pedal required for a given clamping force is a function of the ratio of the caliper and master cylinder pistons. If you balance things out then brake pedal effort will change little. The factory brakes /6 have both larger calipers and master cylinder, but the ratio is little very close to the same. Interestingly the hydraulic line pressure does change, largely based on caliper piston area, which is why the six has a different pressure regulator and why racing applications often replace the it. Very well explained and help clear up the biggest is better confusion ,I'am running 19mm 911 cylinder with 944T four pot Brembo's and find it a well balanced system and stops very well, IMO considering no servo assist it works ....tested it @ close to 100mph to 0 and well up to the job . Cheers |
Lo-Fi Version | Time is now: 26th February 2025 - 07:36 PM |
