What type of plugs you guys running?, other than the Bosch supers..... |
dlo914 |
Mar 21 2005, 03:15 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
im just curious to see if anyone running like the Bosch Platinum +2 or +4 actually felt a difference. Other than that i would assume NGK plugs would also work. Well for most things i already know the 2 or 4 pronged plugs dont get 4 sparks, but it just provides the spark more options to spark to. But i just want first hand experience of others using different plugs, before i purchased a new set of plugs....so bring on the plug info.... (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) o and do these plugs actually increase gas mileage?
jwalters |
Mar 21 2005, 03:50 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
I am using the +4's with a blaster2 coil. My idle improved very much. It was also much easier to get repeat results when tuning the carbs.
AS far as overall hp, prolly don't do much if anything--but that is seat of the pants-- What I can tell you is that there is no electrode wear--the gap stays the same thru its life-- So I did have some improvement--and they were only 5 bucks each. I do run a hot coil tho--some say they foul easy,all depends on the person-- but look at these, 18,000 mi on a slam wore out 1.7--they never hiccup'd or fouled, they sparked always-- (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) And yes, they ARE going into my turbo motor--- Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:08 AM |
