OT: 230v welder wiring, using a dryer circuit |
bondo |
Mar 23 2005, 04:23 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I just got a millermatic 175 welder. 230v, 19.5 amps. I'm going to make an extension cord for it and was wondering what guage wire I should use. Is 12ga enough? (going about 30 feet, just enough to get all the way around the garage, and into the driveway a bit)
Also, the dryer outlet is neutral grounded. Should I use it as is or add a second outlet with a real ground? |
bondo |
Mar 23 2005, 07:00 PM
I just checked the circuit diagram for the welder. It shows the ground going straight to the case, no 115v circuitry at all. According to the manual it should have 2 hots and a ground, no neutrals.
My dryer has a place to disconnect where the neutral grounds to the case. It has instructions for converting it to "real" ground, using a 4 wire plug (still need the neutral for the 115v timer stuff). Apparently some codes do not allow neutral grounding of dryers (do any allow neutral grounding of welders?) Perhaps I should just go 4 wire for the dryer, and just not use the neutral for the welder. I need to go shopping and price out various alternatives. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:18 AM |
