Welding new bellhousing |
86motoman |
Apr 12 2005, 08:37 PM
Member Group: Members Posts: 200 Joined: 13-May 04 From: Walla Walla, WA Member No.: 2,064 |
Is it possible to weld a new or different bellhousing on a transmission?
And if so how? |
Brett W |
Apr 14 2005, 09:07 AM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Well if you are gonna do it might as well go all out. You can run their 7.25 in clutch as well. Lots of Winston Cup cars use these. There are pretty cheap if you buy them used. SO you have to drop the clutch and hammer down from every red light. At least it will look good and sound nice. To run the tranny upside down you will need a pump and some fittings. Just make a fitting to screw into the drain plug. Then build small manifold for multiple lines to exit from. Take each line to different points in the tranny and tap the case and srew in some fittings. Voila' you have a spraybar equipped tranny. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:33 PM |
