Engine turns and fires, then revs then dies, ?Rule out catastrophic engine failure |
echocanyons |
Apr 17 2005, 04:54 PM
Advanced Member Group: Benefactors Posts: 2,096 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Sorted through the fuel pump issues that I was having with the boards help.
Went through the vacuum hoses for the FI system and it all appears to be correct. car is a stock 72 1.7 D-jet NOW: The car turn over fires then revs high to 3000 for a couple of seconds then dies. I remember this happening to my 74 right after it needed a top end rebuild for failure of which I cant recall How should I go about checking to see if the engine has had a failure Compression test? anthing else? Other open ended possibilities that run through my mind are MPS problems, incorrect fuel pressure cuz I still havent been able to find a guage/tester that I can run with inline with this setup. |
Allan |
Apr 17 2005, 08:07 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Is is basically a one way flow valve. Pull the line on the side currently going to the return and see if anything comes out. I don't think you want anymore than about 30 lbs. of pressure. See if you can reduce the cranking pressure down to that and see if it is stable. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:15 AM |
