Bad oil leak... DE in 2 weeks, Please HELP!! |
yarin |
Jun 12 2005, 11:20 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I bought this car a month and a half ago, as a race car with 2 engines, 2 trannies, 2 exhausts, etc etc. I swapped in the "good race" motor being told it was just rebuilt, case split, heads done, dynoed, ready to go. So I finally get everything hooked up, start it up, timing is perfect, but it drips oil. The pushrod seals look ok, its not the drain plug, bottom sump area, the other plate.
The leak is coming from higher up. The cooling fins on the cylinders are wet. Most of the drip is from the drivers side of the engine. There is drip on the shift bar, random spots on the oil pan, and a few other places. I have a drivers ed event at limerock with Jersey PCA and haven't gotten the car inspected yet. I have till tuesday to cancel. I don't have time to drop the engine again and tear it apart. Do I cancel? You can see how bad the leak is in the last picture, moving slowly backing out of the garage, then back and forth a few times. Please advise. Thanks (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0589.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0591.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0592.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0593.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0595.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0596.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0597.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0599.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0600.JPG) (IMG:http://coewww.rutgers.edu/~yarin/914oildrip/IMG_0602.JPG) |
Brett W |
Jun 12 2005, 02:52 PM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
I would replace the rear main seal and check the galley plugs. The heads are leaking under combustion pressures. I would guess the cylinders or heads are not flat. I would also check the oil pressure sending unit as someone mentioned earlier. You can probably check the head bolts, there may not be any sealer underneath the washers, thus causing a leak.
Lo-Fi Version | Time is now: 6th January 2025 - 06:56 PM |
