New NLA 914 parts?, Entrepreneur Opportunities... |
JeffBowlsby |
Jul 23 2003, 10:52 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So if we could have a source for every imaginable NLA 914 part...or bolt-on improved versions what would you want my brothah's and sistah's?
There have been some great items made up recently including Mueller suspension bearings and the RennsShifter...and the lenses and... What else do we need? What can you contribute to this list? What would be first on your list? |
tat2dphreak |
Jul 25 2003, 03:03 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
QUOTE(Bruce Allert @ Jul 25 2003, 03:45 PM) tat2... if you can't cut the Monel I don't know how I could. Not really into metal (just Heavy Metal (IMG:style_emoticons/default/wink.gif) ) It'd prolly look really cool. I can't even imagine how I'd stick it together! Rockaria, If you went South of the border to get the Upholstery done there's a good chance everything was stuffed with cow or horse shit! At least that's what they used to do in the 60's. Cheap upholstery that had an o'dure (IMG:style_emoticons/default/rolleyes.gif) I'm sure you have a really good job and for $500 you got a deal. bruce it cuts with a blade fine(jigsaw/sawsall) just not with plasma(which would mke the job easy)... screws/bolts should hold it fine. I'm assuming the support hardware(brackets etc.) would be the same. don't worry about it though... I'll get som aluminium from onlinemetal.com (unless someone knows a cheaper place) and do it... do you think a 3'x4' piece is big enough for the 2 side pieces? how thick does it need to be(minimum)? I'm thinking 1/8" is thick enough. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:13 PM |
