WOT: ARRGGHHH, i hate fixing someone elses code!, F%^$SH*&@@@ |
SirAndy |
Aug 15 2005, 07:33 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
this was supposed to be a simple stripped down BASE64 decoder done in java.
i don't (can't) use a lot of standard libraries because this App will be run on PDAs and java enabled cellphones, so SIZE does matter. no problem, i get one of my contractors the BASE64 specs and some sample implementations ... he's been fighting with this for 3 days now so i get his sourcefile and have a look at it this morning. looks OK at first glance, but when you run it, it sporadically spits out wrong bytevalues while some decode just fine. wtf? so i spend all day going through his code (which is not that much) and i just can't figure out what's wrong. then finally, about 15 minutes ago it dawns on me, have a look at this: bReturn2[nn+2] = (byte)(iRes % 0xFF); bReturn2[nn+1] = (byte)((iRes >> 8) % 0xFF); bReturn2[nn+0] = (byte)((iRes >> 16) % 0xFF); bReturn2 is a byte array, iRes a integer, the purpose is to roll the lower 3 bytes of the integer into 3 sequential fields in the byte array. i had been staring at this for 6 hours and couldn't figure out what was wrong. all the while it was right in front of me, plain sight, right there ... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) can you find the error? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy PS: did i mention that i HATE going through someone else code? |
SirAndy |
Aug 15 2005, 09:07 PM
we've got a winner! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) he used the "%" operator which is MODULO instead of "&" which is bitwise AND ... took me 6 friggin hours to find that one! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Andy here's the correct code snippet: bReturn2[nn+2] = (byte)(iRes & 0xFF); bReturn2[nn+1] = (byte)((iRes >> 8) & 0xFF); bReturn2[nn+0] = (byte)((iRes >> 16) & 0xFF); |
Lo-Fi Version | Time is now: 27th September 2024 - 07:49 AM |
