Oil Line Routing - question routing under rockers?, how do i avoid this? |
Aaron Cox |
Aug 18 2005, 03:59 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
if i went under the rockers...how do i get it into this passage?
(IMG:http://www.914world.com/bbs2/uploads/blog-1124402022.jpg) go in through the inner fender?? like this? (IMG:http://www.914world.com/bbs2/uploads/blog-1124401996.jpg) and through that void....and into the trunk like this? (IMG:http://www.914world.com/bbs2/uploads/blog-1124402059.jpg) keep in mid...up the passenger side via -10 lines from a mocal sandwich adapter... have heat currently....so would like to run up under the rocker panels.... how would one cover up the lines in the cockpit by the passengers feet? as seen here??? (IMG:http://www.914world.com/bbs2/uploads/blog-1124402504.jpg) |
Jeroen |
Aug 18 2005, 04:07 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
why don't you route the lines farther forward on the outside?
like on the 911, where the line just follows the wheelarch inside the fender Then you can go into the trunk in front of the front wheels... (just an idea) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:56 AM |
