Transmission leak Side Shifter, At the balljoint lever. |
mihai914 |
Aug 21 2005, 10:29 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Hi to all,
So I have this leak from the transmission right under the plastic cover. I didn't remove the cover yet, but I'm sure it's full of gear oil. It doesn't seem to be coming from above the cover so I think it's the seal underneath the ball joint lever as shown in the picture. Anybody went through this, was it a pain to change with the tranny in the car? I'm mostly concerned about the retaining pin, I never had luck with those when reinstalling and always screwed them up. Any BTDT or pointers? Thanks Attached image(s) |
mihai914 |
Aug 21 2005, 11:42 AM
I have on order the seal, o-ring and two pins just in case I screw one up like when I rebuilt the pedal assembly.
So once the 13mm nuts are removed the whole thing can be taken out? It would be simpler than I thought then. Thanks to all who responded I hope everything will go well in my case, I've seen a friend fight with the imput shaft seal and it wasn't pretty. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:44 PM |
