Rewiring, more, step 1, de-wiring |
lapuwali |
Sep 3 2005, 08:09 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I've managed to disentangle and separate the mess at the fusebox and under the dash. Found plenty of PO hackage, and more burnt wiring. I also discovered a few things about the factory harness.
The headlight switch SHOULD have four connections: power in, parking lights, lo-beams, dash lights. You could get away with three, and merge the lo-beams and gauge lights in the harness later. So, why are there FIFTEEN terminals on the headlight switch, with several connections with doubled up wires on them? There's like 20-30 wires there. OK, for ultimate reliability, I suppose you could run a wire to each light individually, plus the gauge lights and power, but that's still only 10 wires... I think some of the final assembly (maybe a dozen crimped connections) was done after the harness was on the car. Some of the assembly must have been pretty challenging. I can see this in a low-volume setting, and it's certainly how I'll make the replacement, but to make around 100 cars per day in this way is pretty amazing. |
bd1308 |
Sep 3 2005, 08:15 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
see that's why I like these cars so much, people's souls went into the production of this fine automobile.....this is before the time of robots.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:52 PM |
