Rewiring, more, step 1, de-wiring |
lapuwali |
Sep 3 2005, 08:09 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I've managed to disentangle and separate the mess at the fusebox and under the dash. Found plenty of PO hackage, and more burnt wiring. I also discovered a few things about the factory harness.
The headlight switch SHOULD have four connections: power in, parking lights, lo-beams, dash lights. You could get away with three, and merge the lo-beams and gauge lights in the harness later. So, why are there FIFTEEN terminals on the headlight switch, with several connections with doubled up wires on them? There's like 20-30 wires there. OK, for ultimate reliability, I suppose you could run a wire to each light individually, plus the gauge lights and power, but that's still only 10 wires... I think some of the final assembly (maybe a dozen crimped connections) was done after the harness was on the car. Some of the assembly must have been pretty challenging. I can see this in a low-volume setting, and it's certainly how I'll make the replacement, but to make around 100 cars per day in this way is pretty amazing. |
lapuwali |
Sep 4 2005, 07:35 PM
Couple of photos:
This is the mess that exists behind the dash. There's about 10lbs of wire there. Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 02:00 PM |
