Vacuum Hose Question, For a 73 2.0L |
billd |
Sep 30 2005, 12:16 AM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
I finished restoring the D-Jet EFI on my 73 2.0L and fired it up. It runs!
However, I have a few questions about routing the vacuum hoses. 1. There are two vacuum fittings on the distributor. A 5mm fitting on the near side (toward the distributor) and a 3mm fitting on the far side. The 5mm appears to go to a connection on the far side of the throttle body. Where does the 3mm fitting go? I've seen pictures that show it going to a fitting on the near side of the throttle body, but there is no fitting there on my car. 2. There are two 11mm vacuum connections on the side of the plenum toward the battery. Where do these go? Does the connection on the oil filler go to one of them and the decel valve to the other? I've seen pictures with a "F" shaped rubber fitting on one of these connections. Is that fitting needed? If so to route to where? Thanks, ----Bill |
TravisNeff |
Sep 30 2005, 12:50 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
The PVC valve is at the base of the filler assy. It is a white plastic disc, you can remove the filler assy from the case and unscrew the PVC vavle from it and replace. Cheap from the dealer, just a couple bux.
Lo-Fi Version | Time is now: 27th September 2024 - 09:47 AM |
