dual valve springs, max. RPM? |
SirAndy |
Oct 4 2005, 11:22 AM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
ok, i'd like to get an educated guess as to what my approx. max. RPM would be with a 2056 with heavy duty dual valve springs, solid rocker spacers, 911 swivels, slightly bigger valves, 9:1 compression ...
as far as i can tell, the components used are good quality. i had the rev. limiter set to 6000 rpm which seemed to be on the safe side. only hit the limiter 2 or 3 times during a AX. always ran plenty of oil, got a tuna can on the motor. no lean running ... the motor always felt like it wanted to pull past 6000 and wasn't done with it's peak power yet so i'm thinking there has to be more ... anyone who can give me a hint as to where the redline could be? ballpark? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
cha914 |
Oct 4 2005, 05:58 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
My Raby 2056, was tested on the dyno up to 7300, by the man himself (Hi Jake (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif)) - ... peak power is at 6300 though.
I have hit 7k in second gear on an autox course, and it woulda kept on spinning if I hadn't noticed, I try to keep my shifts at 6K when I am having fun though. Motor has Cromo pushrods and dual valve springs, and stock rockers with swivel feet. Tony |
Lo-Fi Version | Time is now: 27th September 2024 - 07:55 AM |
