Subaru Conversion, CSOB style... |
jsteele22 |
Oct 4 2005, 03:43 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
I've been thinking about what it would take to do a Subaru install into my 914, and making it as inexpensive (and as home-brew) as possible. I have a friend who is a machinist with a lot of enthusiasm for the project, and a nice shop. He's done a couple of adapter plates before, so I'm confident in that part. What I'm more curious about is the flywheel. My idea for this is to take the stock Subaru flywheel and machine it down to a radius of 4-5-ish inches, and then bolt a stock Porsche (okay, VW) flywheel to it. So the Subaru FW becomes just an adapter hub. Then, the thickness of the adapter plate is chosen to get the input shaft to reach the proper position in the friction plate/pilot bearing. What do all you hybrid gurus out there think of this ? Am I overlooking anything glaringly obvious ? (I haven't seen the pieces in person, just in Haynes & on EBay.) Sure, the assembly will have to be balanced carefully, but I think we (he) can handle that. The engine I'm looking at is an EJ25 (165-ish HP) or, more realistically, an EJ22 (130-ish), so it won't be an axle-snapper like some of you SBC folks are driving. Another issue is the engine mount. I've seen pics of Scott's, and another one (tube steel) that I think Friid had made up, but not the ultra-secret Renegade design. One idea I had on this is to not use the stock Suby engine mount points, but instead make the adapter plate several inches wider than the bell housing. Then each side of the adapter plate could have an "L" shaped bracket bolted (sideways) onto it; the bottom of the L would bolt vertically onto the plate at two points, and the back of the L would point (horizontally) forward to hang from a cross bar, either in the conventional (lower) position, or up high across the top of the engine bay. This would take essentially all of the torque off of the mounting bar bolts, and would leave an open path for the shift linkage. In practice, I'm sure there would need to be a little cross-bracing to prevent side-to-side motion, and also to keep the L from straightening. Again, oh learned ones, what are your opinions on this setup ? I *think* that suspending an engine from the adapter plate is essentially what all the Subaru airplane folks do. I'm really pretty excited about the idea of putting a Suby in my car. And it would be even more cool if it turns out to be affordable. Please let me know what you think.... |
jsteele22 |
Oct 7 2005, 06:14 PM
Hey, that's a pretty interesting idea; there's a lot that I like about it. Much of the engine weight is supported farther forward (at the stock Suby mount points), and no risk of bent bolts like was feared with the sideways bar strategies (connecting to stock 914 mount points on the chassis.) The force on the engine adapter plate will be much smaller in magnitude, will point straight downwards, and have less vibration to contend with. This would swing my vote back towards an aluminum adapter plate (see previous entry in this thread). I think that the suby engine casing doesn't surround the flywheel 360 degrees, but is open at the bottom; so it would be possible to have a thin adapter plate and still have a meaty section at the bottom for bolting the bar into. Also, the bar doesn't interfere with the shift linkage, another plus. I think (we'll have to see) your idea could be used with a mid-engine radiator setup, which I really want to do. The main thing I'm concerned about is just how well the bar will prevent up/down motion of the engine. The P6 engines you mentioned mount to the bulkhead over a very short span, whereas this is a pretty long reach. I'm not saying that there is a problem, only that my first hunch is that it looks kinda spongy. OTOH, the stock 914 mounting scheme struck me as very "airy" at first. (I also thought those guys at CERN were blowing a little too much hot air when they called their cute little idea the "world wide web".(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) ) BTW, I think it is so cool that you can just jot down your ideas in a 3-d CAD system. I just use words or wave my hands around. |
Lo-Fi Version | Time is now: 23rd November 2024 - 04:26 PM |
