Installing starter button, Which red wire is power? |
jgara962 |
Nov 27 2005, 10:46 AM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
Installing a starter buttong inside the car, but there are three red wires coming out of the ignition connector - which is the hot feed that gets connected to the other spade terminal?
From the wiring diagram 15 - which also has a black wire coming out of the same terminal, both going to the fuse panel 30 - goes back to the starter X - on the diagram it goes to a square with the number 49 in it (I have no idea what that stands for) I already have the yellow wire from the solenoid connected and thought the power would be X, but I think I guessed wrong. Thanks!!! |
jgara962 |
Nov 27 2005, 11:01 AM
So I want the black wire coming out of 30 that goes to the fuse panel?
Got a sealed 60 amp button at Kragen - that should do the trick. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:14 AM |
