T fitting instead of prop. valve, what is the rational? |
DanT |
Dec 1 2005, 08:18 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Ok, I know this has probably been discussed in many threads before. But, what is the reasoning for replacement of the Prop. valve with the "T" fitting for the rear brakes. Does the prop. valve cause more line pressure to the fronts or the rears when it is operating properly? I want to understand the engineering aspects of this modification.
I will be running "M" calipers with mythical billet hubs in the front and stock 914-4s in the rear. thanks (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Dave_Darling |
Dec 2 2005, 10:55 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
True. If you lock the rears while you're going in a straight line, and the road surface isn't too irregular, you shouldn't spin. If you're not near the limit of adhesion in any way whatsoever (except of course for the rear wheels sliding), you've got decent odds of not spinning. Then again, this is a race car (or at least a track car) we're talking about.... --DD |
Lo-Fi Version | Time is now: 27th September 2024 - 07:55 AM |
