Brakes, or the Lack of |
Nick |
Dec 3 2005, 05:57 PM
Member Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 |
I spent today installing new rear wheel bearings and that went OK I think. I left the swing arm on the car and just unbolted the rear brake calipers, but left all the lines connected. I backed out of the garage and the brake pedal went straight to the floor. Pumping didn't seem to help. I can see no leaks and the brake fluid is full. I lift the car off the ground again and had a helper step on the brakes. all the wheels locked to the point I couldn't turn them by hand. I guess the question is what should I look at next?
Nick |
Eric_Shea |
Dec 3 2005, 11:19 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
If you suspect a M/C you should check the floor around your pedal assembly. Any failure will probably show up there.
Lo-Fi Version | Time is now: 27th September 2024 - 12:06 PM |
