Rotor Temperatures, Am I getting too fanatical? |
dmilzoff |
Aug 23 2003, 01:31 PM
Member Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 |
Am I getting too fanatical or is this a real problem?
On my 914-6, I have 911 brakes up front and original rear brakes. I found the right rear brake dragging (smoking!). After opeining the vent clearance and oiling the emergency brake linkage, I took the car out for a 4 mile ride. Rotor temperatures using a infrared temp probe was Left Front 145 deg. F. Right Front 150 Left Rear 180 Right Rear 225 Question 1: Shouldn't the front rotors be hotter? Should I remove the brake proportioning valve or replace it with a new one to correct this? Question 2: Is the right rear too hot for such a short ride? |
dmilzoff |
Aug 23 2003, 03:41 PM
OK. So I will replace the brake lines. If that doesn't help, I guess BOTH rear calipers should be rebuilt or replaced. - ? Are they worth rebuilding or should I replace/upgrade?
Lo-Fi Version | Time is now: 27th September 2024 - 06:25 AM |
