Speedo Calibration, need some ideas |
smooth_eddy |
Dec 17 2005, 11:40 AM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
I pulled my speedo this morning and am planning to send it to North Hollywood Speedometer. It is off by 15 MPH at 60 MPH. First, I have to put something on the end of the cable and count revolutions over 52'-9.5" (1/100th mi). Problem is, the cable is too short to get any tape or paperclip on it for a revolution flag. What can I grab the end of the cable with.
Second Q.......the black trim that holds the glass in place is pretty beat up. What is the best way to repaint? How does it come off? Thanks, Eddy |
vertigo |
Dec 17 2005, 12:35 PM
Member Group: Members Posts: 72 Joined: 12-June 05 From: Porterville, Ca Member No.: 4,262 |
Frogot second question. The bezel is crimped around the back. Use a small screwdriver and pull up lip about 1/2 way around. You should be able to remove bevel and glass then. If not keep prying up lip until you can remove. (this must be done to calibrate speedo anyway) Realise that when you paint one bezel the others will probably need to be done also (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) When done use larger screwdriver to press lip back in place. Hope this helps.
Lo-Fi Version | Time is now: 27th September 2024 - 04:13 PM |
