OT: 230v welder wiring, using a dryer circuit |
bondo |
Mar 23 2005, 04:23 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I just got a millermatic 175 welder. 230v, 19.5 amps. I'm going to make an extension cord for it and was wondering what guage wire I should use. Is 12ga enough? (going about 30 feet, just enough to get all the way around the garage, and into the driveway a bit)
Also, the dryer outlet is neutral grounded. Should I use it as is or add a second outlet with a real ground? |
jd74914 |
Jan 16 2006, 11:27 AM
Its alive Group: Members Posts: 4,796 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Just hardwire it and be done once and for all. We finished wiring our garage a few weeks ago and just put in special 50A outlet and breaker in the panel for the welder. Much safer than a huge extension cord and less voltage draw. IIRC we used 8ga wire to link the outlet to the panel. Nice and easy and now we can forget about it. No cords to trip over. Its very simple to do and much easier to run than the four strands of #1 wire that were run from the house to the garage. Pulling those things are hard, wiring a simple outlets not bad and it saves lots of trouble in the future. It should be comprable pricewise to and cord you could make because you only need to buy one plug as opposed to 2 for an extension cord, and then you just need a breaker on top of that and the same length of wire. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Also, like Clayton said earlier, ground and neutral are 2 different things, don't run them together. Ground is ground whereas neutral measures current loss for GFI breakers so that they blow when the current loss it too great, like when you are dancing because you are getting electricuted. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) In any case, go by building code and be safe, that much voltage can hurt really bad (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:11 AM |
