L-jet AAR, help me please... |
bd1308 |
Jan 30 2006, 12:23 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
when the AAR is disconnected and ports plugged, the cold start idle is VERY slow....like a tractor idle or something. I have to bump the idle screw to get it to actually idle.
then it will idle warm at like 1500-1700 RPM...which is way too high. AAR connected, the engine WONT stay running cold(have to rev to 3000 for 1-2 minutes to hold idle)....when warm, the idle is fine...something like normal. ? b |
ClayPerrine |
Jan 30 2006, 12:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Did you plug the hole in the intake tube before the throttle body?
If not, you have "false air" and that will cause lots of idle problems with an L-jet system. Because the air being used for combustion is not passing the air flow meter, it runs really lean. Warm the engine up to operating temp. Plug the AAR, and set the idle speed. This should be the correct warm idle. Any fast idle when cold is controlled by the AAR. |
Lo-Fi Version | Time is now: 27th September 2024 - 02:15 PM |
