Plastigauge mains?, how to? |
goose2 |
Feb 13 2006, 05:33 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
I'd like to do a dry run on my lower end assembly to check main bearing clearances with Plastigauge. I assume I can just bolt it up and torque it down using only the main bearing saddle bolts, with no sealant, to get a reading. It's a 3.0 six. Is this correct?
Thanks, Randy |
LvSteveH |
Feb 14 2006, 01:22 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
With regard to the plastiguage issue, some of the best 911 engine builders prefer to rely on measurements instead of plastigauge. Apparently it is almost unheard of to find a quality bearing out of spec for a 911, and there was some concern about torquing the bearings then pulling it all apart again. I like Jake's idea of measuring the rotating resistance, although I don't know if a 911 would be the same as a type 4.
Lo-Fi Version | Time is now: 27th September 2024 - 08:38 AM |
