brake selection, would this work Eric or DaveP? |
DanT |
Feb 17 2006, 12:29 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I know in the past everyone has discussed using M calipers on the front with stock 914-4 rears along with a T fitting in place of proportioning valve.
What if you were to use the M calipers and 914-4 fronts on the rear utilizing the proportioning valve. would this negate enough of the rear bias with the larger 914-4 front pistons to give good braking? Possibly utilizing a milder rear pad as well with a very aggressive front pad? What do you think....and no I don't care about the E brake. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Thanks |
Aaron Cox |
Feb 17 2006, 10:44 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i have setup A, M's with Tee, porterfield R4S pads and itll stand on the nose....
Lo-Fi Version | Time is now: 27th September 2024 - 04:56 PM |
