Cooling fan ?, Anyone know the degrees per blade? |
ottox914 |
Feb 17 2006, 09:41 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Messing around with some updates to the 914, no problem finding TDC, but my other timing marks are hard to find. As a means to double check my work, anyone know how many degrees per fan blade? Yes, I've tried Mr Search to no avail.
swl |
Feb 18 2006, 09:27 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
The template on the pelican site is great tool. You can use it to do a much better job estimating degrees than blades would. That said, the diagram on pg65 of the haynes manual is pretty accurate I think shows 4.5 blades in 27degrees.
Lo-Fi Version | Time is now: 27th September 2024 - 04:43 PM |
