2.0 D-jet on a 1.7 motor, how easy? |
Trekkor |
Feb 22 2006, 12:11 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I'm guessing replacing intake runners and using either 1.7 injectors or lowering the fuel pressure to lean it out a little?
thanks KT |
Dave_Darling |
Feb 22 2006, 01:19 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Replace the runners with cut-down 1.8 ones. The 1.7 ones are too long and the tubes are too narrow to properly mate up with the 2.0 plenum. The 1.8 ones are at least the same diameter as the 2.0 ones. The 2.0 ones could have holes drilled to fit the 1.7 head, but I don't know if there would be enough room to fit a nut on the two central studs.
The 2.0 injection will run a 1.7 rich. Going to 1.7 injectors, MPS, and ECU should correct that. A 73 2.0 ECU is a 1.7 ECU (same ECU was used for both 1.7 and 2.0 that year) but the 1.7 injectors and MPS ($$$!) would still be needed. --DD |
Lo-Fi Version | Time is now: 26th September 2024 - 11:13 PM |
