Rear wheel camber, ride height, etc. |
ninefourteener |
Feb 23 2006, 08:44 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
Good morning.
I've begun researching installing a shorter spring (which may mean heavier load - not sure) in the rear of the 914. I've never been happy with the way it sits up "higher" that I think it should. Not looking to fork over $$$ for coilovers...... just a shorter spring. I'm running 205s on all 4 corners, and there is VERY little clearance in the rear between the tire and the outside fender. I remember when I installed drop springs on the Acura, The front tires were fine, but the rear camber kinda "kicked out" a bit..... caused the inside edge of the rear tires to wear unevenly. What should I expect? Uneven tire wear? Negative camber? Positive camber? No change at all? Thanks! |
ninefourteener |
Feb 23 2006, 02:30 PM
I'm only looking at going about 1 inch lower...... just enough to balance out the back with the front...... I don't really want a "lowered" 914.
In fact, I'm thinking about just having the current springs cut. I went 2 inches with the Acura on all 4 corners..... I'm only going 1 inch onm the 914, and just in the back. Still think a realignment will be necessary... with only a slight drop? Will it effect it that much? |
Lo-Fi Version | Time is now: 27th September 2024 - 12:40 PM |
