RennShift spring option, read this if you have a RennShift |
JWest |
Sep 11 2003, 12:40 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Hey guys, due to the recent request for heavier springs, I now have replacements available.
The RennShift takes about 7 lbs. at the knob to move side-to-side. I have found this to be well liked by many people, but some may prefer stiffer springs. I now have additional springs available that increase the load to about 13 lbs. at the knob. The stock shifters I have measured vary a LOT, from 9 to 12 lbs. for the most part. These springs can be used on one or both sides, and drop in quickly with the removal of 2 screws at the top of the shift housing. The original torx screws can be a bit of a pain, so socket-head allen screws will also be included. I have used many different variations in my own car, and I like the lighter springs best. If you want the heavier springs, send me a PM and I will send a pair out to you. |
JWest |
Sep 13 2003, 08:02 AM
Rich is correct, 15mm wrench and a hammer. The factory manual actually says to use a "locally made tool" that looks just like a 15mm open end wrench! It's easiest to do on the car before you remove the shifter, just don't get your face in the trajectory of the knob when it comes off!
The crush sleeve is available new for about $2. The RennShift is designed to use the stock knob. You can see the stock knob is installed on the RennShift on the website www.rennshift.com |
Lo-Fi Version | Time is now: 27th September 2024 - 12:08 PM |
