Transmision Mount Replacement |
kconway |
May 8 2006, 10:34 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm going to attempt to change my tranny mounts with some 911 sport mounts I got from Pelican. I think I'm removing the two small 15mm bolts that hold the mounts to the chassis while supporting the tranny with my jack? Anyway, will the old mounts just simply pull thru the ears forward? I assume I've got to drop the tranny a bit to clear the supports on the chassis, is this correct? What about the big bolt, do I gotta loosen it? What am I missing?
Thanks, Kevin |
Mueller |
May 9 2006, 12:07 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I'm going to attempt to change my tranny mounts with some 911 sport mounts I got from Pelican. I think I'm removing the two small 15mm bolts that hold the mounts to the chassis while supporting the tranny with my jack? Anyway, will the old mounts just simply pull thru the ears forward? I assume I've got to drop the tranny a bit to clear the supports on the chassis, is this correct? What about the big bolt, do I gotta loosen it? What am I missing? Thanks, Kevin if you don't loosen the big bolt, the mount will not seperate from the transmission (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 05:28 AM |
