Body filler, Do NOT use plastic |
tdgray |
Oct 2 2003, 08:39 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Here is prime example of 1) how not to fix a rust spot. 2) NEVER NEVER NEVER use plastic body fillers. I'm sure at one time this was a small hole or rust spot that was fixed with plastic filler (Bondo and the like). Plastic fillers attract water and hold it thereby rusting any and all unprotected metal underneath. Not to mention that this was a very poor repair job in the first place.
Attached image(s) |
tracks914 |
Oct 2 2003, 05:58 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Water proof and proper prep work is a must. Glass bead or sand blast all rust out. Clean with paint thinner and prime with 2 part epoxy primer base coat within 1 hour. After that you can use just about any bondo type material you want. Just don't put the bondo on the bare or rusty metal.It will never stick long. Biggest concern from here is, wait long enough for it (bondo) to completely dry before final sanding and painting. It will shrink and ruin a good paint job if you try to rush.
Lo-Fi Version | Time is now: 27th September 2024 - 04:16 PM |
